cleaning a car cover????
I will be doing the same to mine. I am not sure if it is all cotton or Poly/cotton but I believe it will be easy to wash in a washing machine. I will be using a mild liquid laundry detergent under the delicate cycle. Then dry it under low for a few minutes then hang it outside in case it might shrink in the dryer.
Oh, just did a search and uncovered a few tips. I believe this is honda's instructions for cleaning but I could be wrong:
"The cover can be washed while it is on the car, using a small amount of Liquid Fantastik Cleaner and a soft brush or sponge. Use water to completely rinse off the cleaner. Leave the cover on the car, or draped over a clothesline or wall, and allow it to air dry. The cover can also be washed in a large automatic washer found in most commercial laundromats. A home-sized washer is too small. DO NOT use a washer with an agitator as this can rip or tear the fabric. Use two (2) cups of Liquid Fantastik Cleaner. DO NOT use soap or detergent. Cover can be washed in warm water. Water must not exeed 185 degrees F. Run it through two rinse cycles. It is very important that the cleaner is thoroughly removed. If the cover is dried in an automatic dryer, use "low heat" or "air" setting only! The cover can also be air-dried draped over a clothesline, wall or on the car."
Here's the thread:
https://www.s2ki.com/forums/showthread.php?...?threadid=64103
I am surprised this isn't a static note in the "Wash and Wax" forum. Well hope this helps!
Here's the thread:
thanks alot. i definitely don't have a large washer so i'll have to find a laundromat.
i don't like the idea of washing it on the car though...also, the inside is caked with sand too (surprised to have found that).
laundromat, here i come.
let me know how yours comes out.
jeff
jeff
