2nd Gear grind at lower RPM's
Old 09-01-2004, 01:24 PM
  #21
Billman250's Avatar
Received 1,402 Likes on 839 Posts
Fluid change....suck it out with a turkey baster, use small pieces of paper towel to remove the black sludge in the bottom of the master. REFILL the master to the top. Open the bleeder, allow 90% of the fluid to just run out. The trick is to close the bleeder before the fluid gets low enough for air to enter the tiny hole. Close bleeder, refill to the full mark, which is a good 3/8" from the top.
Freeplay...push the clutch lightly with your finger while looking at where the rod goes into the master under the dash with a flashlight. Adj it so it barely moves in the back of the master.
Bill, it may look like you're out of threads, but don't worry. There's plenty there to adj it right.
Old 09-01-2004, 01:41 PM
  #22
g-s2k's Avatar
BILLMAN TO THE RESCUE AGAIN!!! THANKS BILL!
Old 09-01-2004, 02:44 PM
  #23
Legal Bill's Avatar
Now I have to find some good Dot 3 fluid. I read that Dot 3 lasts longer than Dot 4. What do folks here usually use?
Old 09-01-2004, 02:51 PM
  #24
Legal Bill's Avatar
Originally Posted by g-s2k,Sep 1 2004, 05:05 PM
I know I'm not Billman But I'll toss my two cents in here
1. Both are appropriate ways of flushing the clutch fluid. But the Tureky Baster option just saves time.
2. How much play do you see with light finger pressure?
Glenn, the free play gets taken up in two steps. As I push with my finget the pedal travels about 1/2 inch and stops, but with just slightly more pressure it goes another 1/2 inch and then it really stops. In other words, I can feel that I have encountered the hydraulic system and not some return spring.
Old 09-01-2004, 02:53 PM
  #25
Legal Bill's Avatar
Originally Posted by billman250,Sep 1 2004, 12:13 PM
When adjusted correctly, you should barely be able to see the rod move in the back of the master when applying light finger pressure.
^ I assume that you before you encounter heavy resistance. I ask becuase as soon as I touch the pedal I see the rod going into the master. But the first inch of travel seems to be free play.
Old 09-01-2004, 03:04 PM
  #26
Billman250's Avatar
You'll feel all kinds of weird stuff. Bottom line, watch the piston in the back of the master. The piston will have it's own play in the master. But the play between the end of the ROD where it sits in the master, and the master PISTON, should be almost none. enough that you can barely see.
Old 09-01-2004, 03:05 PM
  #27
Billman250's Avatar
PS...if you want some overkill good fluid, use racing brake fluid such as Motul or ATE super blue...
Old 09-01-2004, 08:00 PM
  #28
Legal Bill's Avatar
Well, Billman was correct, there was plenty of adjustment available even though at first glance it looks like the rod is in by three threads. On first attemp I followed Billman's advice as close as I could. I drove the car and right away I could feel a difference in the clutch. It seems to be fully disengaged well before the pedal hits the floor. My first to second shifts felt fine, but the real test will be when I am not concentrating on them and just driving normally. The clutch fluid was very dark and needed flushing. I used the Billman technique of sucking out the old stuff first, refilling, and just opening the bleeder screw. I did use one of those hose and bottle things that catch all the fluid so you don't get a mess. I just used Castrol GT LMA fluid. I'll use the big dollar race stuff for the brakes.
So in summary, it feels better and it is easy to do. All took about an hour including the road test and this write up.
Old 09-02-2004, 06:45 AM
  #29
g-s2k's Avatar
WHOO HOO!!!
Old 09-02-2004, 08:49 AM
  #30
Billman250's Avatar
This is actually what I use in my S2000 customer cars
Quick Reply: 2nd Gear grind at lower RPM's
