Brake Shops
Originally Posted by KrazyKarim,Jan 12 2005, 02:32 PM
What do you need done to your brakes Ry?
Ryan
Originally Posted by Ludedude,Jan 12 2005, 05:26 PM
You need to get the spacers ahead of time. I'd be surprised if any place had a selection of spacers in stock that covers all the necessary widths and different bolt patterns out there
Ryan
You're swapping calipers and rotors? It's a kit made for the S2K? If those are both true then there's no reaosn Dustin can't handle it. The smartest thing to do would be to find out what spacer is needed with your particular rim. Maybe see if you can get a template of the caliper to make an edumacated guess?
Ryan
Yeah, so the install should be no big deal. Just make sure he has an impact driver to remove the rotors and a 10 mm line wrench to deal with the brake lines. Other than that it's all just basic hand tools.
If anything, I'd guess the Stoptech caliper is bigger than the brembo one so if their template fits you could be fairly confident the sizing is close.
