Nevada S2000 Owners Las Vegas, Nevada and area
alignment question
Old 03-16-2008, 02:01 PM
KrazyKarim's Avatar
Do you have huncentric rings for your rims? That could be a cause also
Old 03-17-2008, 09:42 AM
C8V6C's Avatar
Nope, dont have them on the S...Id be willing to give them a shot....
What Ill do is swap my stock wheels on, try them, and if there is no shudder at high speeds, Ill try the hub rings and the alignment
Old 03-17-2008, 05:51 PM
Enthralled's Avatar
I'd check the tire for pressure, nails and anything else first. this car is very finicky..
Old 03-17-2008, 07:46 PM
C8V6C's Avatar
Tire pressure is good...no nails....good balance...I dunno.
Old 03-18-2008, 10:19 AM
WhatNoise?'s Avatar
[QUOTE=Enthralled,Mar 17 2008, 05:51 PM]
Old 03-19-2008, 12:56 AM
juntuned's Avatar
[QUOTE=WhatNoise?,Mar 18 2008, 10:19 AM] Like a pussy hooked on Fancy Feast
Old 03-19-2008, 01:52 AM
KrazyKarim's Avatar
Originally Posted by juntuned,Mar 19 2008, 12:56 AM
I doubt hubcentric rings will do anything...
I can't for the life of me think of anything else it could be.
As far as I know Shawn's car hasn't been in in accident so I doubt it's a bent suspension piece. Tires are in balance so we know that's not an issue and I doubt his wheels are bent as that's something the tire shop wouldn't noticed when they balanced his wheels.
Lack of hubcentric rings on aftermarket rims are a very common cause of vibration on s2ks with aftermarket rims. Most rims are made to fit a large selection of cars causing their center bore to be bigger than the s2000s hubs. We actually ran into this on Jimmys (LVGPwhite) volks. After he got the rings from discount the vibration was gone.
Here is a good paragraph that also explains it
[QUOTE]Hubcentric rings are designed to fill in the gap between the
Old 03-19-2008, 01:53 AM
KrazyKarim's Avatar
Old 03-19-2008, 02:01 AM
Enthralled's Avatar
Originally Posted by KrazyKarim,Mar 19 2008, 02:52 AM
As far as I know Shawn's car hasn't been in in accident.
Actually, someone did hit his front quarter panel a while back while he was parked at work.
Old 03-19-2008, 02:07 AM
KrazyKarim's Avatar
Ah ok then it very well could be a bent suspension piece
Quick Reply: alignment question
