S2000 convertible fix in Dubai
Hi there,
I was wondering if any of the S2000 owners in Dubai had fixed/replaced their soft top convertibles?
need some guidance.
Thank you
need some guidance.
Thank you
I recently did a patch up work on my soft top. Let me know exactly what work you need to get done and i will try my best to help
Iv got a very tiny tear on my soft top and wanted to get either a patch or rePlace the section with a new one. But also if U no of an upholstery place who does convertibles I wouldn't mind changing the whole thing..
Thanks
Aziz
Thanks
Aziz
anyways, i have patched up the cut on my car, and it has been sealed properly and the cut is hardly visible. If your soft top is in good condition other than the cut, I'd suggest to do the patch work as i was quoted a very high rate for replacing the soft top. If you are free this week, i can come along with you to the shop.
By the way, did you buy the car recently? I noticed at a number of places where you placed an ad for "want to buy"
hi sherzad,
maybe you can help me too. i have a cut like 6 inch long on my top and another 2-3 inch. its a pain seeing it like that.
i was qouted nearly 4k dhs for a repair lol, dont have funds for that at the moment.
Originally Posted by Abdul Aziz' timestamp='1347652054' post='22012355
Hi there,
need some guidance.
Thank you
need some guidance.
Thank you
I too have the same issue, two nasty tears which i have patched up from a random upholster it does need refixing every now and then. Willing to try out your guy if he can do a nice job..\
Thanks for the info!
All S2k owners have the same problem, some more than others depending how often you open and close your soft top and how much its parked under direct sunlight. I changed mine the first time under warranty. I don't think you'll find a cheaper quote than 4k, and you have the risk of quality. So I have decided to completely remove the soft top including mechanism and save some weight.
I also need to change the seat upholstery if anyone knows a good shop in Dubai.
Ummss2k
21
09-30-2006 04:50 PM
