Car Diagnostic (CEL)
Hi,
Does anyone have an idea where to get a through car diagnostic test done? My 2006 S2k's CEL (Check Engine Light) lit up just after a service from Honda (Change oil, differential oil change, etc).
I brought the car back to Honda a day after to get it checked. The Honda guys seem to be perplexed as to what caused the CEL to light up. They said they ran the car in their diagnostic tool and error codes turn out to be something related to the battery. There's no problem with the battery at all so they assumed that it's just a random ECU error. They reset the computer after that to get rid of the CEL, but it turned back on again after just 200kms of driving. I'm very apprehensive to bring it back to Honda again.
Any suggestions? Thanks!
Hi
Do a search on this site for CEL reading, and you will find a thread telling you how to bridge the diagnostic port so you can read them yourself.
Either that or try to get honda to read it again, and then post the reading in the "engine" forum. I am sure someone else will have had the same before.
Originally Posted by dennisp,Jul 28 2009, 10:42 PM
Hi
I was on my way to work this morning when the CEL light switched off by itself after a refueling session. This is really weird. I've read on some forums that ECU's sometimes adjust to changes made to a car. Is there any truth to this? Moreover, I haven't done any modification to the car at all apart from the recent maintenance service.
the Ecu adjusts to the way you drive IIRC - but thats all I know.
I would pull the ecu fuse (and check it) for 10 minutes, and then plug back in. If it comes on again then at least you know its thrown for that reason and get straight to Honda for a reading.
Not sure if it could be a dodgy earth or loose connection somewhere????
that same thing happened to my S and it turned out to be that my catalytic converter was going bad after throwing the code for the O2 sensor. but nothing registered until i got the car back from Honda Service Center for oil change. Best of luck with your S
