AP2 Exhaust
AP2 Exhaust
For sale is my stock exhaust (without tips) off an 04. Has about 60k miles on it. In good shape. SOLD
The exhaust tips are slightly damaged on the bottoms. I didnt notice the damage until the exhaust was off the car. The tips are filthy (tar etc.) as you will see in the pictures. SOLD
I also have a T1R testpipe, that came with a used exhaust I recently purchased. Its banged up. See attached pictures. $50 picked up.
All items located in Norfolk Va.
Thanks,
Chris
Thanks,
Chris
You want $100 for the exhaust and bighead will give you $50 for the tips. I'll give you fifty for the rest but I only really need the exhaust from where it meets the cat to where it splits. You could basically cut it off right at the dual split and that's all I want.
Feel free to contact me at 7577056458 or rcp@vansantgusler.com
Thanks,
Chris
Jeff if you really want it I have no problem letting it go to you. I'm not even 100% sure it will fit my car right because I'm 06+. I've heard of several exhausts having fitment issues. I thought it would be cheap enough to find out though. If not I'll go with my original plan of putting a vband flange in right before the dual split so that I can remove the rear section separately and then I'll make a straight pipe section to swap on when I want to drop some weight and make some noise.
