Ugh. Continued clutch problems.
Old 02-06-2004 | 07:17 AM
sweetj's Avatar
How many miles do you have and have you had any of the TSB's done?
Old 02-06-2004 | 07:18 AM
heffergm's Avatar
62,000 miles. I've only owned the car for about the last 1000 miles of that, so I can't answer that question.
As I paid $14k for the car, I expected to have to do some work to get it in order.
Old 02-06-2004 | 07:34 AM
sweetj's Avatar
Congrats on your purchase... I've had mine from the beginning... She will be 4 next week and has a little over 50k on her right now... Lots of TSBs have been done and no clutch replacement yet.. although I did have the deceleration fixed and the 1-2 grind fixed...
Old 02-06-2004 | 07:38 AM
heffergm's Avatar
Interestingly enough, my car doesn't grind any gears. It's pretty notchy, but no grinds....
I suspect the car was somewhat neglected in terms of maintenance, but not driven terribly hard. Regardless, everything seems to be squared away now. Now if the damn weather would take a turn for the better, I'd be a happy camper...
Old 02-06-2004 | 07:56 AM
brerspidur's Avatar
ok, . .heres the update, i pulled out the "worthless" hondacare extended warrenty. it seems that although "powertrain" is covered up to 100K(which they usually say that its the other part of the warrenty that you need. there is one fun little sentence that says that the warrenty on non-powertrain components is extended 1 year or 12K miles. so now i called my service dept and they are going to look at it monday. im going to be sure to drop the car off the night before so they can look at it cold, before it has warmed up and the problem goes away.
Old 02-06-2004 | 08:09 AM
heffergm's Avatar
The problem is, NO powertrain warranty is going to cover clutch replacement. It's a wearable part, like brake pads. They might do a good faith replacement under warranty, but I seriously doubt it.
Old 02-06-2004 | 08:16 AM
FF2Skip's Avatar
Glad Curry's took care of you.
I basically have the same problem when it's really cold. Guess it's time to flush the clutch fluid. Which in turn means, I'll probably flush the brake fluid as well. Thanks for posting.
For the record, my car has never been driven hard.
Old 02-06-2004 | 08:36 AM
brerspidur's Avatar
i hope its not the clutch, . .and if it is, then there was somethign wrong with how they put it in, because since i had the TSB done, the new clutch barely has 5000 miles on it, i doubt it should wear that quickly when the previous clutch had over 30K
Old 02-06-2004 | 03:11 PM
gfacter's Avatar
Your Avatar would suggest otherwise
Old 02-08-2004 | 11:46 AM
RazorV3's Avatar
The place is a complete zoo... WAY too many cars coming and going for my taste.
, sad but true(and it sucks for employees!)
Andersonracing
01-13-2015 03:21 PM
js2k2005
05-06-2012 05:48 PM
yoursyumiko
01-10-2012 05:37 PM
Marco
01-03-2001 09:53 AM
Red_s2k
10-15-2000 12:23 PM
Quick Reply: Ugh. Continued clutch problems.
