SRS light
If you search the forum, there is a way to reset it with a jumper wire and use a resister to keep it off if you have harnesses. I personally never bothered though. Do you know why its on?
He pulled the seat belts, so the SRS computer couldn't find the seat belt tensioners when it checked the system. The resistors should fix that, so now he just needs to clear the codes using the jumper plug under the dash (unless it's an '06 or later).
youngturk
11-27-2017 07:20 AM
