Replacing wheel stud
Does anyone know of anywhere that I could go to have a rear wheel stud replaced? One was crossthreaded and broke the stud off when trying to remove it.
Pretty sure you're going to have to replace the wheel bearing at the same time. IIRC, there's no room to back out the studs without removing the hub, which pops the bearing open. Or you could reuse the bearing, and see if it lasts afterward, but from everything I remember, replacement is recommended.
Topgear is right....The wheel bearing has to be pressed out, while being pressed out it gets ruined. Once the bearing is out it only takes a couple taps of a hammer to get broken or crossthreaded stud out and new stud back in. A shop should just charge you for replacing wheel bearing.
Any of your local shops would be able to do this. I would recommend a shop that can do the press work in-house. If they have to send it out to a machine shop or to a different shop with a press it will take much longer and they'll just take their bill and add a few bucks on to yours.
I agree, the hub has to be removed and the bearing will be destroyed. My Honda dealer charged $550 for a hub and bearing replacement. You may be able to get that stud's thread cleaned up with a tap-and-die, especially if only the first few threads were messed up.
Here's what's involved in doing a bearing swap: http://robrobinette.com/S2000Bearing.htm
Why did you replace the hub?
Is there any chance you'd be willing to help me with it?
There is a small shop on East Gude Dr that did a bearing replacement on my car last year for ~$260 in labor. I can't remember the exact amount. They were able to reuse my hub.
Not sure if they have much S2000 experience, but they did a nice job on my car. I can dig up their contact info if you want it, Dan.
For another option, George really likes this guy: https://www.s2ki.com/s2000/topic/820...t__p__19571106
