OEM hard top question
Old 05-11-2010, 02:06 PM
2Kaputnik's Avatar
Default OEM hard top question
Hey Guys - I think I have my sights set on a OEM hardtop (thanks for lead vbb ). Should there be any problem fitting the top in the back of a Toyota Tacoma (older, smaller model) pickup for transport? I've got a shell on it, but I can pop that off. It's a bit of a haul, and I'd rather not transport it home on the S2K in some half-assed manner.
Might host an install party if this goes down (hint...get it?). Thanks and see ya'll soon.
Old 05-11-2010, 02:21 PM
9k_on_occasion's Avatar
It's probably just a bit too wide to fit lengthwise, so I think you'll have to load it sideways and let the front hang over the side. Bring lots of thick blankets and comforters for padding, and some bungee cords and loading straps to keep it from bouncing around.
Another option is to go ahead and install the side catchers now, pick up the top with the S, then make the final adjustments once you get back.
Old 05-11-2010, 02:44 PM
2Kaputnik's Avatar
^^ Thanks. I'll probably just pack it snug in the back of the truck like that. All the hardware is with the top anyway.
Old 05-11-2010, 02:51 PM
magikcow's Avatar
installing the OEM top takes 30-40 minutes at the most. It's just a couple of bolts for the most part I believe.
Old 05-11-2010, 04:19 PM
TheDarkKnight's Avatar
Git it! Mine fit in my HHR. It will def fit in a Tacoma!
Old 05-11-2010, 04:32 PM
2Kaputnik's Avatar
Planning on it this weekend!!
Old 05-11-2010, 06:01 PM
vbb
vbb's Avatar
I'm glad to see it worked out for you Roland!
Old 05-11-2010, 06:21 PM
C Ory's Avatar
Negative on that statement.
All the rear plastics have to be removed in order to get the rear latches in. And it takes a little bit of time to get it adjusted just right. It's not a hard job by any means, but not a 30 minute job either.
Old 05-11-2010, 08:09 PM
2Kaputnik's Avatar
As always - thanks guys! Just gonna pick it up in the Tacoma and bring it home.
Old 05-12-2010, 04:37 AM
C Ory's Avatar
Quick Reply: OEM hard top question
