need help with clutch.
My clutch been acting up past few days. It has gotten really soft with alot of play in it. and becoming harder to shift into gears. I went to check the fluid and it was low. So I filled it up and notice it was really dark so I know it is time to flush it and refill. Only problem is I have no tools so I cant do it myself nor I want to. and everyplace Ive been calling around wants to charge 80-100 dollars for the drain/refill. There might be a leak as well? maybe the clutch line needs replacing and I was quoted 400-500 dollars for that so f that. everyplace Ive been to as well say my car is to low to get on any of their lifts.
So I need someone around the williamsburg area that can be able to change the fluid, and possible replace the line as well. I will pay for all work done to it, and of course pay you for your time, with money food and beer
You need to put your head under the dash, and look at the firewall and see if the Clutch Master Cylinder is leaking. If so, then you'll need one of those. If you were a little closer, I would be more than happy to help you out. Maybe one of the Newport News/Williamsburg people will chime in, and be able to help you out.
johnquester2000
34
02-20-2012 10:43 AM
dainese919
19
03-11-2009 09:55 AM
