Need coil packs / ignition coils - CEL HELP!
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-5yr.png)
I am in Richmond, Va and recently got a CEL for misfiring cylinders. More than one. I just replaced the spark plugs tonight and still have a slightly rough idle. I will get the check engine light diagnosed tomorrow and cleared to see if it comes back. I'm guessing the ignition coils need to be replaced. Anyone locally able to assist me with testing coils?
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-10yr.png)
Misfiring can cause by bad spark plug, bad coil pack, bad EGR valve or even bad Cam sensor. Double check with engine diagnostic code!
Sent from my iPhone using Tapatalk
I had a CEL due to the valves needing to be adjusted. If you do adjust them, go over them multiple times before putting everything back together
If that's still not it I have a couple extra coils laying around if you make the trip up.
![banghead.gif](https://www.s2ki.com/forums/images/smilies/banghead.gif)
