Local source for torque wrench repair?
So I busted the drive end off my torque wrench trying to get the axle nuts loose after everything else has failed. Anyone know of a local place (MD/DC/VA/DE) where I can get it repaired?
You know you are only supposed to tighten bolts with a torque wrench, not loosen right? That said you are probably better off just buying a new one from Harbor freight or something vs trying to get one repaired, unless its was a super expensive one.
I broke a 1/2" breaker bar the last time I tried to remove the axle nuts. This time, along with the torque wrench I also broke a 3/4"-to-1/2" adapter using a 3/4" breaker bar and a 1/2" socket.
Use a bigger breaker bar and correct size. I never trust adapters, i've broken a few in my day.
If that does not work then get nasty and use a 1000 ft/lb impact.
Originally Posted by Insert Name' timestamp='1313523368' post='20883838
Breaker Bar FTW.
I'd scrap the wrench and just buy a new one unless it is an expensive one.
Specs:
Drive: 1/2″
Avg. Air Consumption: 5 CFM
CFM at Load: 24
Speed – No Load(RPM): 9500 BPM (Blows per minute)
Max Torque ft/lbs: 1000
Working Torque ft/lbs: forward – 625, reverse 700
Inlet size: 1/4″
Min.Hose Size: 3/8″
Std. Bolt Capacity 9/16″
Length: 7.34″
Weight: 3.95 lbs
Bit expensive yes. Little trick, add any compressor and the 2135ti to the shopping cart on sears website and it'll take 25% off. Then delete the compressor if you already have one and the 25% should stick, then do local pickup. Currently $194 and a bit for it w/ 25% off.
http://www.sears.com/shc/s/p_10153_12605_00919288000P (shows $260 without the 25% off)
Hope this helps Warren. If you need any help local let me know. I'm in Owings Mills myself, I actually have axle nuts I have sitting here I need to put on as I didn't have the patience immediately after doing my clutch change.
Originally Posted by WarrenW' timestamp='1313533753' post='20884414
[quote name='Insert Name' timestamp='1313523368' post='20883838']
Breaker Bar FTW.
Breaker Bar FTW.
[/quote]
I've had that much trouble. But it was because we forgot to unstake them.
Ingersoll Rand makes one. The 2135Ti, I highly recommend it from personal experience.
Specs:
Drive: 1/2″
CFM at Load: 24
Inlet size: 1/4″
Min.Hose Size: 3/8″
Length: 7.34″
Weight: 3.95 lbs
Specs:
Drive: 1/2″
CFM at Load: 24
Inlet size: 1/4″
Min.Hose Size: 3/8″
Length: 7.34″
Weight: 3.95 lbs
