Harddog rollbar install
Hi everyone,
If everything goes according to plan, I should be picking up steve's harddog roll bar next weekend. I was wondering if anyone has the dvd that has been circulated among the mid-a members? I'm also wondering if anyone would want to lend a hand? I have a shop with a lift I can use, unfortunately I can only use it on Sundays. I have an air compressor there, but I don't have the tools to cut with, and I don't think my dremel will cut it. I don't have a grill there, but I can buy you guys pizza .
The shop is located in Manassas, VA. Its quite small and parking is pretty limited, so I don't recommend you bringing the S down, whenever I schedule this.
good luck with install. i did mine in a night. worse part is the interior removal and cutting rear wheel well area for the mounting bracket. we used an air saw, but i think a higher rpm dremel with a good cutting wheel will do the trick and prob be a cleaner cut. suggest welding it back when installed to avoid any water getting in there and starting rust issues.
juno1996
01-29-2016 08:26 AM
gcxnirvana
01-17-2015 05:34 PM
TritonS2k
03-23-2004 04:46 PM
