Front Spoiler Removal
Does anyone know how to remove the front spoiler? I know I have seen it posted, but I can't find it with a search.
Do I just remove the bolts along the bottom of it and the two screws (or whatever they are) on each side facing the wheels? How do you remove those two screws on the side?
Thanks
Thanks
Did some more research and determined that the screws on the side are self-tapping screws. So, my only question now is are these removable without damaging the screws? If so, how?
Thanks
Thanks
You might want to post a picture...but otherwise it sounds like the answer to your own question is that there are no screws at the wheelwell points of the lip. So just remove the umpteen 10mm bolts from under the bumper attaching the lip...and the lip will drop for you mucho-presto.
I installed the oem lip myself .. on the sides where clips that went on fender and the phillips head screws attached the lip to fender on side .. along front you have to replace the front few screws after you take lip off .. they are stock . the others went into clips you place in grove of bumber . i would take those clips back out after you take it off ...
