Coilover Install -- WILL PAY FOR HELP!
Old 08-10-2011, 09:34 AM
  #21
9k_on_occasion's Avatar
Hmmm. If you've already popped the lower ball joint, I'd say bolt the upper A-arm back in (to hold the spindle), unbolt the lower arm and see if you can get anything to loosen up.
Old 08-10-2011, 11:18 AM
  #22
Apeatwo's Avatar
Any updates?
Old 08-10-2011, 01:49 PM
  #23
biXs2k's Avatar
Originally Posted by Beepbeep
I think it's the same, I wish I'm not at work so that I can send my pictures of install. Anyway, remove the two bolts (17MM Ithink?) that is at the end of "Y" end of Lover "A" arm bolted by the inner fender side.
I finally freed the trapped strut. I had to remove the entire lower control arm, as stated above. I'm going to do the rears tomorrow, and hopefully I don't run into another 'trapped strut'! Thanks for the help -- I'll post a couple pictures once it's done!
Old 08-11-2011, 02:31 AM
  #24
Uncoolron's Avatar
Jeremy Clarkson
09-11-2012 11:27 AM
biXs2k
08-10-2011 06:15 PM
yakswak
01-23-2005 07:08 PM
Quick Reply: Coilover Install -- WILL PAY FOR HELP!
