car is missing under full throttle
Left class last night and one my way home a buddy of mine with a SER Spec-V pulled up behind me. After getting a red light we took off. I ran 1st all the way out hit 2nd and about half way through 2nd it popped. Then i shifted into 3rd gettin back into it did it agian. But the car idles fine and when i am not in it is fine. So last night I made some calls and herd spark plugs, coils, and bad gas. I am thinking that bad gas might be the problem. I replaced my spark plugs less than 4 months ago with NGK's. But i still am not to sure just looking for a little help
Brook
Brook
Check your plugs. Same thing happened to me after I switched plugs, turned out that the plugs were damaged due to over tightening. Did you use a torque wrench when you installed the plugs? Honda only recommends 19-20ft/lbs I believe.
I had a the same problem, i chaged the map sensor, cleaned the terminals on the connector and put a tie wrap around the sensor and connector to keep them secure. For good messure i did an injecter service and throttle body cleaning. car has been running fine ever since.
Originally Posted by TheBlack01,Jan 25 2007, 12:16 PM
Left class last night and one my way home a buddy of mine with a SER Spec-V pulled up behind me...
Possible?
