best plugs
Old 09-30-2006, 02:33 PM
TheBlack01's Avatar
Default best plugs
ok well after my water in intake thing i am pretty sure my plugs are bad or at least almost. so what are the best plugs to run?????
thanks
-brook
Old 10-01-2006, 08:34 AM
dmw16's Avatar
i always ran bosch plugs in my last car and they worked really well. I am not sure if there is something that makes one plug good on one car and not on another. So that would be my suggestion. THe Titanium Bosch plugs.
Old 10-01-2006, 04:15 PM
SWIFT2000's Avatar
I would stay with oem plugs
Old 10-01-2006, 04:22 PM
4theheckof_it's Avatar
Horrible recommendation......
If you're stock, and not FI (which you would use 1-2 steps colder), then use the oem NGK or Denso's.
Old 10-01-2006, 04:43 PM
dmw16's Avatar
Thanks for setting me straight.
Like I had said, they worked well on my FI american car.
Old 10-01-2006, 06:22 PM
Matt_in_VA's Avatar
Question? How long will the stock plugs go based on a Stock AP1 motor? The spec is 100K miles. What is practical and realistic? How about, valve adjustments? What interval is realistic?
Old 10-02-2006, 08:33 AM
TheBlack01's Avatar
which would be better to run Denso Iridium or NGK platinum
Old 10-02-2006, 10:02 AM
Poindexter's Avatar
I found these Plugs on eBay. Not sure which ones are the best, but you can't beat eBay
Old 10-02-2006, 11:21 AM
CrazyCracker82's Avatar
bump for ngk's
i use the 7173's but i'm FI
Old 10-02-2006, 12:32 PM
CaptKirk's Avatar
I have heard from other credible sources also that bosch plugs aren't the best choice for our cars. I have NGKs and they run fine... I'd say just get some NGKs for the stock NA application.
Quick Reply: best plugs
