Alignment Help
Alignment Help
I'm trying to find out what the:
1. Factory alignment specs are
2. What the suggested alignment specs are for autocross
3. Local (near Catonsville, MD), trusted mechanic to go to for alignment
Thanks,
Don
G. Obadia (333, I think) sent me some of this info, but I lost it. Please help me out!
Thanks,
Don
Factory Specs are
Left Front
MIN NOM MAX
-1.5 -0.5 0.5 Camber
5 6 7 Caster
-.04 0.00 0.04 Toe
Right Front
MIN NOM MAX
5 6 7 Caster
-.04 0.00 0.04 Toe
Front
MIN NOM MAX
NONE 0.00 NONE Cross Camber
NONE 0.00 NONE Cross Caster
-.08 0.00 0.08 Total Toe
Left Rear
MIN NOM MAX
-2.0 -1.0 -1.0 Camber
0.2 0.24 0.28 Toe
Left Rear
MIN NOM MAX
0.2 0.24 0.28 Toe
Rear
MIN NOM MAX
0.4 0.48 0.56 Total Toe
Those are stock specs.. all i can help you with ... sorry
Left Front
MIN NOM MAX
5 6 7 Caster
-.04 0.00 0.04 Toe
Right Front
MIN NOM MAX
5 6 7 Caster
-.04 0.00 0.04 Toe
Front
MIN NOM MAX
Left Rear
MIN NOM MAX
0.2 0.24 0.28 Toe
Left Rear
MIN NOM MAX
0.2 0.24 0.28 Toe
Rear
MIN NOM MAX
Guys and gals are using Radial Tire(or something like that) in your area. I know TubeDriver, gfactor, and SweetJ use this shop. I'll be buying my RA1's from them and they do corner-weighting. Supposedly they setup quite a few track cars.
Yup but they don't do alignments (not sure about corner weighting). Great place to get and mount tires. Allen automotive is right around the corner (in Silver Spring). Radial Tire uses them for alignments. They are a little hole in the wall shop but they have fancy alignement racks and will do custom specs for $75. I have had them do alignments and was satisified with the work.
[QUOTE]Originally posted by FF2Skip
don you will need more camber than that in the rear. at least 2.5. also ask for as much caster as possible its about 6 degrees. again go to allen auto 301-587-6755.
1.5-6 f cam
2.5 r cam
0 f toe
1/4 total r toe
6 deg caster
1.5-6 f cam
2.5 r cam
0 f toe
1/4 total r toe
6 deg caster
I don't think they do corner weighting but I am not sure. Gfactor knows a Porsche race shop that will corner weight correctly but they charge mucho bucks (approx $400).
Are they the ones that do corner weighting?
