over rev question
over rev question
Hi guys,
So i was driving around and i was in 2 gear and i accidently bounced the rev really quick and shifted to third (some bitch wouldnt let me in the lane) i barely bounced off if and shifted and drove around to see if anything went wrong, what should i do to check if i messed up a valve or something? there is no check engine light. ( my car is stock) any suggestions
if your upshifting 1-2-3-4 etc and you hit the rev limeter thats fine, its an electronic rev limter to keep your motor safe, the way you hurt the motor is with a mis shift, ie tryin to go 3-4 and go 3-2 when you miss shift goin down there is no electronic rev limter to save you, the motor will rev untill you let off, and thats how you mess stuff up
Originally Posted by roadents2k,May 10 2008, 01:00 PM
I messed mine up when i was going 1-2 and 2 didn't go in and i got back on it
Originally Posted by Chi-CityAp2,May 10 2008, 12:43 PM
thanks alot guys im trying to learn the s2k haha thanks for the replys
In a nutshell, mechanical over-rev can happen when you hit second instead of fourth, from the top of third (for example). The tires force the engine to spin WAY too fast, if even just for a moment. It "overpowers" the limiter, in a sense.
So what happens if your driving from 1-2 then shifting to 3rd but the rmp was pass the 8k mark * so it was like blinking for a sec or 2 * will the rev-limiter kick in? or did i kill the motor...
