new goodies
new goodies
My new wife brought me some new JDM goodies... J's Racing Intake, ASM Radiator Plate and ASM Struct Tower Brace.
Question - the J's intake snorkel part doesn't seem to extend as long as others that I've seen in pictures here. Is this a revision by J's? Also the intake came with only page 1 of the installation instructions. Does anyone have the entire installation instruction set?
Call AJ-R. They will give you the full instructions.
I thought that the shortened J's intakes were the normal Js intake price +$250. I was not aware that they changed anything or made all of there intakes designed to fit the Type S bumper if thats what your referring to. BTW...nice parts.
Ryan
Ryan
Maybe I'm not describing it correctly. OK, look at these pictures...
At the very end of the snorkel, the mouth or opening seems larger and longer than mine is. Is mine a different version than these others?
I just talked to Ben @ AJ-R and he told me that I have the regular version, not the short ram. The short ram is one foot shorter. So I guess J's revised the design a little, maybe for the AP2?
1)Remove your stock airbox. Disconnect all the hoses and pipes which attaches to the intake. Disconnect the hose to the valve cover and to the intake pipe.
2) install that rubber piece (with two side thread) on to the right side of the chassis beam (the beam underneath the airbox). Then bolt the vacuum purde valve on the rubber piece with two side screw. Re-hook the vaccum lines.
3)Install the step hose (black) on to the Tsuchinoko. Attach the filter to it as well. Make sure the backing piece of the snorkel sits behind the filter (you will need to bolt it back to the snorkel later.) Now install the Tsuchinoko to the throttle body.
4)Attach the V-shape bracket on to the stock air box mounting location. Fit the snorkel, align it to the Tsuchinoko then bolt everything together by using the bolts and hose clamp which comes with the kit.
5) Drop the hood but DON'T close it all the way. Look betwwen the gap and make marking whewre to cut the back side of the hood.
If anything that I didn't explain clearly, please PM or email me
Thanks
Ben
Thanks
Ben
Hey mav, I want to upgrade that snorkle part.
You have the one for the Type S bumper and I have the other one. Perhaps we can work something out if you are interested, because I will need this snorkle once I fit the J's Racing Type S bumper. Something like a trade!?
