Mounting Rear Over Fenders?
What is the best method to mount rear over fenders to the s2000? I need something that will secure over fenders firmly without damaging the fiberglass over fenders as well as the rear quarter panel, but also be easy enough to remove.
I keep reading to use rivnuts. Thoughts/opinions?
http://www.cardinalcomponents.com/fasteners.htm
i plan on using timeserts but will confirm with my body guy.
rear overs won't be on for a few months but i was planning to space them out a bit as well. details forthcoming
Any links to the timeserts that you will be using?
I did a search online and the results mainly came up with thread stripping and helicoil comparisons.
no ideal til i can talk with my body guy. i liked caseygw's method.
i may decide to not be lazy one day and take pics of mine. cut out, then had new pieces fitted using an english wheel, then welded in, then ground down, then painted. all rivets were drilled out, and timeserts were put in the stock quarter panels so the fenders can be put on and off with allen head machine screws. my paint/body guy is excellent...and youd probably cry if you knew how good his prices are
