JDM F22C Piston
JDM F22C Piston
Anyone have the part number, I have a friend in Japan that can pick these up for me bt his Japanese is only so-so and a part number would make things so much easier.
I found out they are 18,570 yen each. Not sure if they are the same as the USDM yet though. What makes me think they are is that the rated power on the JDM and USDM AP2s with the F22C is the same.
They run a differant headgasket, or atleast they did on the 2.0L. their fuel is the reason why. So if the compression published is the same in Japan and the US, than all is the same. If not, than the Head gasket is all you are really after.
