E-manage Ultimate 101
Old 02-06-2010, 04:25 PM
  #211
scareyourpassenger's Avatar
Greddy gave me the wrong ones. I didn't save the correct ones but Scott at Ballistic might be able to help you out. Heck if you are NA I would just suggest purchasing the pretune as it was so close to a custom one.
Old 02-06-2010, 04:27 PM
  #212
FYI, we have a tuning event in Atlanta with Holy Roller Dyno.
https://www.s2ki.com/forums/index.php?showtopic=763587
Old 02-07-2010, 05:59 AM
  #213
razzele's Avatar
Quick question.
I have fitted a Greddy turbo kit myself. Along with wide band AFR and Boost Guages.
The tune is INCREDIBLY/UNDRIVEABLY rich !
The AFRs are below 10:1 (off my guages scale)
It goes so rich under application of anything more than 10% throttle that the engine simply floods.
What could be causing this in the base map tune?
Old 02-19-2010, 08:41 PM
  #214
Ahnold's Avatar
Originally Posted by razzele,Feb 7 2010, 06:59 AM
Quick question.
Stock or adjustable Fuel Pressure Regulator?
Old 07-04-2010, 01:55 PM
  #215
Kitesurfer s2000's Avatar
Make sure airflow input 2 is set to Aux out ?????? what bit is that ahhh getting fed up now connected up vtec changed jumper 17 to 1 and 2 now i dont know how so control it on the emu can anyone help please
Old 07-18-2010, 08:31 AM
  #216
ap1_tot's Avatar
Originally Posted by gilbertg,Aug 17 2009, 08:58 AM
Boomslang harness is correct for VTEC, GReddy harness is not and needs modification. Make sure airflow input 2 is set to Aux out and also make sure that you explicitly upload the map as sometime the upload does not actually occur when switching features on and off.
What does this mean sir? Im experiencing the same thing here, using the Greddy universal harness as well. Boy this E manage ultimate thing is REALLY driving me crazy. My tuner said on the F20C configuration it wouldnt change the VTEC but if it was on K20 the VTEC could be altered. Also the car is misfiring at VTEC, even when the configuration was set to F20C.. can someone chime in please?
Old 07-29-2010, 06:40 AM
  #217
mjschrage's Avatar
Where can I get the software if I'm getting a unit used, and the seller doesnt have the CD.
Anyone willing to part with theirs?
Old 10-12-2010, 08:49 AM
  #218
s2konroids's Avatar
Guys,
I'm looking inside the board now i have an E revision (this kit came from a greddy turbo kit+greddy harness PnP harness last year).
I see jumper 17, by reading the diagram on the first page i take it the jumper should only cover 'PIN 1'? - i can see on the PCB board the letter one next to the pin.
I also see J8 should be 1-2 NOT 2-3?
I presume this is what OPEN means?
Do i just follow the diagram on the first page as its 100% correct?
Thanks
Old 10-12-2010, 09:16 AM
  #219
urBan_dK's Avatar
Originally Posted by Irvatron,Oct 12 2010, 09:49 AM
Guys,
Thanks
E Revision is the latest board, so you're good there.
Yes, JP17 should be open (cover only pin 1 so none of the 3 pins are bridged). You will also have to rewire your Greddy harness like I PMed you earlier.
JP8 should be 1-2, it probably came wired 2-3 which could eventually burn your coils.
The diagram on the first page of this thread is correct.
Old 10-12-2010, 11:56 AM
  #220
s2konroids's Avatar
Super thanks.
Quick Reply: E-manage Ultimate 101
