E-manage Ultimate 101
Old 09-24-2009, 08:23 PM
  #201
nsx_bob's Avatar
is the emanage ulti and harness interchangable between ap1 and ap2?
Old 09-25-2009, 12:01 PM
  #202
fuel4blood's Avatar
From the information I gathered NO
Old 09-25-2009, 04:52 PM
  #203
Mor.gan's Avatar
Yes and No
00-05 can use the same harness.
06+ (which is Drive By Wire) needs a different harness.
Old 11-14-2009, 02:31 AM
  #204
3r1k's Avatar
I bought E-Manage Ultimate from a guy who bought Greddy Turbo Kit.
Can I just upload a tuned map to the unit and drive the car w/o playing the jumpers and hardware configuration?
Thanks
Erik
Old 11-15-2009, 03:04 PM
  #205
drhess06259's Avatar
if the jumpers were set to a s2k, then yes, if not then you need to set them for the s2k.
Old 12-01-2009, 03:37 PM
  #206
mattdtuck's Avatar
Ok I have a question that hopefully someone can help with. I have some experience with wiring and tuning and understand the basics. My problem is that I bought a greddy kit from a member on here used. He hadn't put the kit on his car, so when I got it, it had a lot of things that I had to do to complete it. It came with a everything as far as e-manage ultimate, with a boomslang harness (im told). After getting the kit installed I can't get the car to crank. It's a AP1 kit and all looks to be right. I can crank the car if I plug back in the stock ecu. So I think my problem is in the harness. Its not showing any ignition on any of the tables when trying to crank. If anyone knows where I can find a diagram of the wiring on the greddy/boomslang harness, I can trace back and see if there are any wires in the wrong pinout. Any help will be greatly appreciated!! Thanks!!
Old 12-28-2009, 01:12 AM
  #207
andys2000belgium's Avatar
open up the emu and double check your jumper setting before you start messing with the harness.
Everything else you need is in the first page's
greetz
Old 01-18-2010, 02:10 PM
  #208
Kinetic S2k's Avatar
what nneds to be modified on the Greddy PnP harness ?
Old 01-27-2010, 04:11 AM
  #209
razzele's Avatar
The equipment that arrived with my emanage (from a greddy turbo kit) plugged in and the car started right away with no changes to the wiring or base map
Old 01-30-2010, 04:54 PM
  #210
s57_s2k's Avatar
I have just received my jumper setting for ap2 with (E board) from greedy :
JP1=OPEN
JP2=OPEN
JP3=OPEN
JP4=OPEN
JP5=OPEN
JP6=OPEN
JP7=1-2
JP8=2-3
JP9=OPEN
JP10=2-3
JP11=OPEN
JP12=OPEN
JP13=OPEN
JP14=OPEN
JP15=2-3
JP16=1-2
JP17=1-2
JP18=OPEN
JP19=1-2
JP20=1-2
are they correct ?
am going to set JP8=1-2 but I dont know about JP15 ?
Quick Reply: E-manage Ultimate 101
