Cooling plate or Spoon Snorkel?
Hey guys- was looking at getting a spoon snorkel for improved airflow - then stumbled across this..
http://www.evasivemotorsports.com/merchant..._Code=SEIBON_CP
. What do you guys think? would this be a better buy then the snorkel? or would this even work? Thanks for the input.
That plate wont do much at all IMO. I would go the snorkle route and leave the oem plate it, it has holes up to the very front to so air will flow throughout the entire engine. If you cover that up with a coolant plate the only hole will be directed to the intake and the rest of the engine will run hotter. I heard its necessary for the coil packs...
![th_dontknow.gif](https://www.s2ki.com/forums/images/smilies/th_dontknow.gif)
Originally Posted by qbmurderer13,May 6 2008, 11:11 PM
That plate wont do much at all IMO. I would go the snorkle route and leave the oem plate it, it has holes up to the very front to so air will flow throughout the entire engine. If you cover that up with a coolant plate the only hole will be directed to the intake and the rest of the engine will run hotter. I heard its necessary for the coil packs... ![th_dontknow.gif](https://www.s2ki.com/forums/images/smilies/th_dontknow.gif)
Originally Posted by kenstyle,May 14 2008, 11:58 AM
there are plenty of replica snorkels on ebay
i believe muz makes replica snorkels as well, or at least used to
