asm rear overfender question
Old 06-23-2009, 07:12 AM
  #131
nichigo's Avatar
^^Not sure what we're looking at...but if all you did was shave down the inner lip of the overfender, then you're AT +25mm. By default, the overfenders do not provide +25mm of width until you cut the lip.
Old 06-23-2009, 08:03 AM
  #132
nichigo's Avatar
Originally Posted by berlinas2k2,Jun 23 2009, 08:01 AM
I thought it was understood that the flares add +25 and then additional if you cut the lip>
Nope I'm pretty sure they add next to nothing when the lip is not shaved. I've had them installed with and without the lip. With the lip, the overfender sits right up against the oem fender...giving it a wider "look" but not adding any clearance at all.
You have to cut the oem fender AND the overfender lip to get the full +25mm clearance.
Old 06-23-2009, 01:42 PM
  #133
SpaS2K2005's Avatar
thats the impression i got too untill i measured it... when you cut the oem fender you get about 15-20 mm and then the over fender trimmed gives you about 5-10 mm so i guess it all depends on the specific fender that you have cuz sometimes the molds are different.
Old 06-23-2009, 02:23 PM
  #134
nichigo's Avatar
^^yeah that sounds reasonable...some overfenders might be more "flared" than others.
Old 06-23-2009, 10:11 PM
  #135
Suzuka_Joe's Avatar
here it comes. wait, wait, OH SHIT!!!!
it'll turn out great jeremy
Old 10-09-2009, 01:58 PM
  #136
CourageOO7's Avatar
Very informative thread. Thanks guys!
Old 10-10-2009, 07:44 PM
  #137
TrackStar's Avatar
Pics . . .
Old 12-20-2009, 08:21 AM
  #138
craig2teg's Avatar
Can a 275 tire fit under the asm rear overfender w/the rear qtr cut and 0 camber?
Old 12-20-2009, 08:31 AM
  #139
CourageOO7's Avatar
0 Camber? Oy...that's gonna be tough. I have a custom set of CCW wheels. They are 10 inches wide and will be running a 295 series rear tire but run negative camber for handling purposes.
Old 12-20-2009, 01:16 PM
  #140
craig2teg's Avatar
Yea I was thinking that was gonna be kinda rough. I plan on ordering a concave set of the current 5Zigens I have. How much camber do you think? They're 10 in wide as well.
Quick Reply: asm rear overfender question
