asm rear overfender question
Old 04-12-2008, 02:36 AM
solomonster's Avatar
Default asm rear overfender question
i have a quick question... how much more MM does the asm rear overfender add?
Old 04-12-2008, 05:11 AM
Dressed2Kill's Avatar
25mm if you cut the oem rear fenders.
Old 04-12-2008, 05:26 PM
i heard you can just roll your fenders flat? is that the same as cutting?
Old 04-12-2008, 05:53 PM
CU Nick's Avatar
No, rolling is not the same as cutting. With cutting you are increasing the arc size of the fender. If you don't cut the fender and still put a much wider wheel with the over fenders, the tires will still rub on the stock panel.
Old 04-12-2008, 07:50 PM
desmond's Avatar
the cutting part was like cutting myself >< VERY PAINFUL!!!!!!!!
but in the end it was well worth it...and NO i do not cut myself...
Old 04-12-2008, 07:53 PM
desmond's Avatar
a lot of people roll it and then pull it up or out because they said they might want to go back to stock and remove the over fenders...BUT the rivets holding the over fenders on require you to drill into your rear QP and rolling the QP and pulling it up or out is WAY more difficult to return to stock...etc...just my .02
-Des
btw, i cut about a good 2.75 inches and almost passed out in the process
Old 04-15-2008, 10:04 PM
h17am's Avatar
Did you do anything else except cutting it? Like any reinforcements, etc?
Old 05-21-2008, 08:28 PM
tsanhd's Avatar
-Des
im still debating if i should cut my quarterpanel im scared...
Old 05-21-2008, 09:20 PM
3vilmonkey!'s Avatar
Yeah this is my only scare... does anyone have pics of the cut w/o the fender on??? haha
Old 05-22-2008, 07:11 AM
Sinji's Avatar
grabbed these from gus' post
Quick Reply: asm rear overfender question
