New s2k owner asking for modding advice
Old 10-05-2024 | 03:35 AM
Chuck S's Avatar
The rear axle nut correction is simple. All you need to do is tighten the nut one flat (60°) tighter than it is now. Requires removing, cleaning, greasing, reassembly, and staking the nut but that's all in the notes in the library. I had to stand on the 18" breaker bar to get the full flat.
Anyone in Richmond reading along? I have the socket and breaker bar and you're welcome to borrow it.
-- Chuck.
Old 10-05-2024 | 04:47 AM
blueosprey90's Avatar
Billman warned us of this issue. Not saying the OP should panic, but should be aware, double check and then monitor every once in a while.
Crank Walk Adventures: Thrust Bearing Failure - S2KI Honda S2000 Forums
Old 10-06-2024 | 01:08 PM
cosmomiller's Avatar
Well what do you know. I was completely unaware of this thread and the possibility of incorrectly installed thrust washers from the factory. I just may have to check this out. I hope Honda solved the problem on their own as my 2009 was one of the last S2000s made.
danger dan
11-18-2013 06:25 AM
(S2K4ME)
05-25-2007 05:06 AM
asjunk
03-21-2006 05:54 AM
SilverKnight
08-15-2005 08:56 AM
HarleyMB41
04-02-2004 03:51 PM
Quick Reply: New s2k owner asking for modding advice
