compression test?
Primary thing is to make sure the numbers are consistent across all 4. Depending on the compression tester used you can see anything between 150-230psi. Not all gauges are calibrated the same.
So you are saying only reason I might have lower compression psi is due to comment above? I thought It should be somewhere between 200 to 240, isn't 150 too low? I would expect b18 motors to be around 150 to 170 psi.. then again I don't know what i don't know.
Thanks!
