Finally.... pics of my Hardtop Hoist!
Old 10-15-2002, 06:59 PM
JonasM's Avatar
I wanted to create a hoist that would properly position the hooks at the appropriate places on the bottom and edges of the hardtop, and also minimize swaying of the entire top (which would scare me too much). I didn't like the hoists that I've seen that are all rope or straps, so I decided to build a frame out of PVC pipe, attach some pulleys to the top for lifting, and hang the hooks down from the frame using nylon webbing attached to the PVC. It's probably way overengineered, but that's my style!
Here is the result:
Here's a side shot of the top over my S: (note the boat winch that I'm using to raise and lower the top. This makes sure that all lifting and lowering is done under careful control).
A couple more views:
Here are the hooks. I used cartop carrier hooks from Sears Hardware. The front ones are bent a little tighter to properly get between the rubber seal and the top. After several months, and many installs/removals, I haven't seen any ill effects from these hook positions.
As long as I park reasonably close to the right position, it only takes me 3 minutes or so to put the hardtop on or take it off. I crank with one hand, and steady the top and position it with the other. Since I've installed this, I've gotten more use out of my top, since I can decide at the last minute whether I want it or not, and can deal with it without help.
Well, there it is!
JonasM
rj.baker (11-08-2022)
Old 10-15-2002, 07:38 PM
dlq04's Avatar
Received 5,016 Likes on 3,032 Posts
Nice. I know you put a lot of thought into it. However, seeing it hanging there reminds me when I had one on another sports car and I use to store it in a similar way. I swore I'd never be bothered with a removable top again.
Old 10-15-2002, 07:51 PM
xviper's Avatar
WOW! That is really slick. You certainly did think that one through.
Old 10-15-2002, 07:56 PM
JonasM's Avatar
[QUOTE]Originally posted by xviper
[B]WOW!
Old 10-15-2002, 08:35 PM
schwett's Avatar
Originally posted by JonasM
ISince I've installed this, I've gotten more use out of my top, since I can decide at the last minute whether I want it or not, and can deal with it without help.
nice hoist.......
i just pick mine up, lift it over my head, step into the car, and basically sit down, putting the top in position, since most of the time when i want to install or remove it, my better half is not around.
Old 10-15-2002, 08:58 PM
S2000typeR's Avatar
Haha! I've never tried that schwett. Do you have to be like really strong to do that?
Old 10-16-2002, 04:04 AM
JonasM's Avatar
[QUOTE]Originally posted by schwett
[B]
nice hoist.......
Old 10-16-2002, 08:38 AM
Woodson's Avatar
That looks great.
One thing that would make me nervous though: Have you thought of putting rebar or something similar inside the PVC pipes? I'd be worried that eventually the PVC would weaken to the point of breaking under the weight. The rebar would prevent your HT from dropping onto your car.
P.S. obviously I'm NOT an engineer.
Old 10-16-2002, 08:48 AM
JonasM's Avatar
[QUOTE]Originally posted by Woodson
[B]That looks great.
Old 10-16-2002, 08:53 AM
Woodson's Avatar
Quick Reply: Finally.... pics of my Hardtop Hoist!
