Yellow Box Speedometer Re-Calibrator?
For those of you (Steve?) that swapped out your FD, do you use the 'yellow box' to fix your speedo? If so, where did you get it from?
hey mark, long time no see around here. anyway, here are 2 options for you to consider:
http://marketplace.s2ki.com/s2ki/product.p...44&cat=6&page=1
http://ricks2k.com/products/yellowbox.php
check out this thread to read about the differences between the two:
https://www.s2ki.com/forums/index.ph...pic=335138&hl=
I got the Yellow Jacket, does the same thing as the Yellow Box but its cheaper and uses dials instead of dip switches. I installed the differential with 4.57 gears today, and the Yellow Jacket is going in tomorrow.
It's the one at this link:
http://marketplace.s2ki.com/s2ki/pro...4&cat=6&page=1
Hi Mark! Yes, I use the yellow box. Works like a charm. Mike (mice) installed it in 10 minutes and we tested it on a stretch of measured straight road by the airport.
Thanks guys. I ended up ordering the yellow jacket since it was cheaper. I can't stand getting extra miles and seeing 75mph when I am going 60. Hopefully it won't be much longer.
