what does the 60k service at honda....
they reccomended it to me in a letter, but i aint goona go there...i need my limbs and dont wanna pay an arm and a leg.
so i just wanna know what they're gonna do so i can go do it myself....(yeah with mugen carbon kevlar duct tape)
TIA
TIA
60,000 miles/4 yrs Scheduled Maintenance
Recommended service for your 2000 Honda S2000:
Replace engine oil.
Rotate tires.
Replace engine oil filter.
Inspect front and rear brakes.
Check pads and discs for wear (thickness) and damage.
Check calipers for leaks and check tightness of mount bolts.
Check parking brake adjustment. Should be fully applied within 9 to 13 clicks.
Inspect tie-rod ends, steering gearbox and rack boots.
Check steering linkage for looseness.
Check fluid lines for damage and leaks.
Inspect suspension components.
Check bolts for tightness.
Check condition of ball joint boots for deterioration and damage.
Inspect driveshaft for cracks and check boot bands for tightness.
Inspect brake hoses and lines (including ABS). Check the master cylinder, proportioning controlvalve and ABS modulator for damage and leakage.
Check all fluid levels, condition of fluids and check for leaks. If needed, add transmission fluid, engine coolant, brake fluid, power steering fluid, and windshield washer fluid.
Inspect cooling system hoses and connections.
Check for damage, leaks and deterioration.
Check for proper fan operation.
Inspect exhaust system. Check catalytic converter heat shield, exhaust pipe, and muffler for damage, leaks, and tightness.
Inspect fuel lines and connections. Check for leaks.
Replace air cleaner element.
Inspect and adjust drive belts.
Replace micron air filter.
Replace differential oil (use SAE90 hypoid gear oil, API classification GL5 or GL6).
It is interesting that I don't see a valve adjustment there. I usually do it on my car about every 15k/2 yrs or as needed. I think that the norm is every 30k though. I think I may be due up actually.
I did it on my friend's S at 50k miles.
Most of those inspections there are visual. You guys are lucky that you have a timing chain though.
i just need a oil change and get my doors werked on. one window broke and the other one...shit at the car show a flyer that someone put on my window sliped into the door! i was pissed! dammit put that shit under the windshield wiper and have some class!
