Hawaii S2000 Owners S2000 Owners in Paradise Hawaii Owners
Lower Intake Temp
Old 08-20-2005, 09:16 AM
PAKS2K's Avatar
Default Lower Intake Temp
Has anyone here done this mod to their car? Seems like you guys with all the cooling mods might be intrested in this.
https://www.s2ki.com/forums/index.php?showtopic=315015
Old 08-20-2005, 09:36 AM
mice's Avatar
Very interesting. Probably work great here in areas where it doesn't freeze. Thanks for the link.
Old 08-20-2005, 12:36 PM
kent-k's Avatar
does anyone use the heater here?
i got the a/c on full blast most of the time. got icicles hanging from my earlobes some days.
Old 08-20-2005, 01:20 PM
smccurry's Avatar
This looks like a great mod for Hawaii owners. Great link Bruce.
It's a much easier/cheaper way of bringing down the intake air temps without the hassle of installing the Hondata intake manifold gasket (which performs the same job).
Like the link says, it's probably a 10 minute DIY job and a couple of dollars spent for ball bearings from Home Depot.
Hondata gasket is approx. $75 for gasket, and $250-$400 for install (3 hours or so with experienced mechanic).
Hondata option is better, since you are placing insulation between the head and intake manifold, but for the price and convenience, this simple solution looks great.
Who's going to be the local guinea pig?
Old 08-20-2005, 02:23 PM
808style's Avatar
i was reading about this too the other day and it seems like a simple mod that definitely lowers temperatures. i'm probably gonna end up doing this, i just need to find a place that sells ball bearings.
Old 08-20-2005, 02:48 PM
MugenRioS2k1's Avatar
I could only find them at ace hardware 23 cents a piece and it only took 6.8 min to put them in (yes i did use a stop watch) I even took a phone call during the install (speaker phone). Not sure how much Hp was gained but I can feel more punch at the low end when I floor it.
The thermal manifold gasket would yield better results due to the reduction of thermal heat transfer. But this is defiantly worth it. Even if you only gain 2 HP/2 TQ then ratio of HP/TQ gained vs. price is worth it.
I hope someone dynos the before and after results I would like to know the actual gains.
Old 08-20-2005, 06:21 PM
808style's Avatar
what size ballbearings did you get?
Old 08-20-2005, 06:43 PM
3/8inch
Old 08-20-2005, 09:36 PM
1-S2k-2-NV's Avatar
I read this the other day and decided to do it yesterday local pig here I can tell you there is no hesitation now which was kinda bad at higher temps before. Great modi for cheapo Hey Mike, did you get my pm about the cover?
Old 08-21-2005, 02:28 AM
PAKS2K's Avatar
Can't wait to do this mod.
Quick Reply: Lower Intake Temp
