Im New but i really need help
Does anyone knows of any mechanic that will work with the S2K? If cheaper than the dealer the better? i had a misshift and im guessing i messed up the #1 intake valve, my computer was reading codes of p1399,p0301,302,303,304 and p0300 ( alot of misfire codes basiclly) Thank you.
we used a bore scope and the piston looked ok, but we did a compression check the #1 was low, and the we did a pressure check and air came out tru the intake side. pulle dthe valve cover and saw that the intake wur stuck out but none of the rest.
i would say about $600 for removal and replacement of the head, and $5-800 worth of machine work at the machine shop depending on how bad the damage is. you could probably find a used head for that ammount of money and swap it in for much less down time as machining of the head can take anywhere from 1-4 weeks depending on how busy the machine shop is. where if you have a used head they would inspect, pressure test and resurface all in a day or two.
Originally Posted by Jazielomar,May 15 2008, 11:04 PM
just wondering im new to this and i just bought the S2K a week ago, u knw where i can find head? lol.
https://www.s2ki.com/forums/index.php?showtopic=580846
u have an ap1 right?
