!$@#%^ 160th Official Hard Work Thread !$@#%^
#1341
Originally Posted by magikcow,Jun 30 2008, 09:18 AM
Anyone know of anyone selling RSX type S rims?
17x9 flat black Non-staggered Enkei RPF1s.
#1342
Originally Posted by 4WheelCBRR,Jun 30 2008, 08:18 AM
from your comments, since you said it happened at hard-cornering, you have to dial-up the compression dampening, I think.
KWV3 experts might be able to help you better.
What tires and wheels OEM?
#1344
Originally Posted by Vadster,Jun 30 2008, 09:14 AM
I performed successful red-neck damage control and bent the lip back in with a wooden spoon from the kitchen. There is still a noticeable lip though. I knew these KW's wouls be overkill - I got out the instructions to try to figure out what I could do to maybe stiffen them up some? I could not make heads or tails of any of it - all I gathered was that they are not user friendly as every other sentence seemed to be warning...
Ja du canst twveak sem some, but du vill run ze risk of breaking zem if you are not carevul vis dem, ja?
ugh nevermind.
ugh nevermind.
You need to tighten both the upper and lower adjustments. Unfortunately, to do the lowers, you need to put it on jack stands. That part is kind of a PITA...
But the uppers, just put that little purple handle on it and turn in the direction of the little + on the handle.
You doknow that you can make these things SO stiff that they knock out your teeth, right?
#1345
Originally Posted by gfacter,Jun 30 2008, 08:21 AM
Me thinks the car is way to low...
I am running 18's
rears 8-1/2 +50 offset Bridgestone RE760 255/35Z
fronts 7-1/2 +48 offset Bridgestone RE760 225/40Z
#1347
Originally Posted by Vadster,Jun 30 2008, 09:19 AM
It looked like I would have to remove them from the car before I made any adjustments... the schits too confusing for me - I fail.
You don't even have to take off the wheels; just get it up in the air so you can reach the bottom adjustment with that un-bent paperclip thingy you got with them.
#1348
Originally Posted by magikcow,Jun 30 2008, 09:21 AM
Rock Band is ready for a comeback tour. Today, Harmonix announced Rock Band 2 is set to ship for Xbox 360 this September and PS3 later in the year.
#1349
Do you have the KW sheet with the baseline settings? Just re-set the dampers to those settings. Maybe add a bit more rebound (top of shock)
#1350
Know anyone with a fender roller? Bill can hook you up if you can get the car up here in August...
