%!&#*378rd Official Hard At Work Thread!%&#!*%
#801
![corner.gif](https://www.s2ki.com/forums/images/smilies/corner.gif)
#802
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-20yr.png)
Originally Posted by WhrDLMI' timestamp='1468431272' post='24015672
Totally. Just like wiring up a lighting fixture. ![thumbsup.gif](https://www.s2ki.com/forums/images/smilies/thumbsup.gif)
![tongue.gif](https://www.s2ki.com/forums/images/smilies/tongue.gif)
Lighting fixtures are usually either hardwired or plug in, since hardwired fixtures are meant to terminate in some box. If the fixture is a plug in you can't really just cut the plug off and run the cable to a receptacle and make it hardwired, at least not easily in compliance with code. Only Romex and in wall cable is approved for behind walls, and lamp cord/regular extension cords run behind walls are against code.
In the case of this disposal, I think you can remove the bottom metal plate (which acts as the box), undo the wire nuts to remove the plug, and wire nut the romex (or bx) connections onto the disposal and replace the metal plate..
#803
![](https://www.s2ki.com/forums/images/s2ki/ranks/com_organizer.png)
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-10yr.png)
![coffee-01.gif](https://www.s2ki.com/forums/images/smilies/coffee-01.gif)
#804
![iamwithstupid.gif](https://www.s2ki.com/forums/images/smilies/iamwithstupid.gif)
#805
![icon_smile_urstupid.gif](https://www.s2ki.com/forums/images/smilies/icon_smile_urstupid.gif)
#806
I'M FAMOUS! ![woohoo.gif](https://www.s2ki.com/forums/images/smilies/woohoo.gif)
https://courses.linuxtrainingacademy...al-world-info/
It looks cheezy but I am really happy with the way Jason used my comments and stand by what I said.
Those of you who expressed interest in the class before should have received an e-mail from Jason with that link by now. If anyone else is interested, I have a 40% coupon code ($299 instead of $499) for the course. Just ask...
![smile.gif](https://www.s2ki.com/forums/images/smilies/smile.gif)
#807
I can see that you all are so impressed that you are speechless.
![rofl.gif](https://www.s2ki.com/forums/images/smilies/rofl.gif)
#808
#810
Originally Posted by WhrDLMI' timestamp='1468423889' post='24015548
It used to be common to mount an outlet under the sink and then just plug the disposal into that outlet. Dunno if that is still done or even code these days...
![suspect.gif](https://www.s2ki.com/forums/images/smilies/suspect.gif)
![a080.gif](https://www.s2ki.com/forums/images/smilies/a080.gif)
