Shift Knob
Shift Knob
I think I am going to purchase a shiftknob. What I would like is one lower than stock, countersunk i think its called. Any ideas on where/what to get. Also this may sound dumb but how hard is the install. How do u install?
Thanks, Aaron
Thanks, Aaron
Install should be easy. If it's like the OEM knob, you'll need a 14 mm wrench to unscrew the nut (push the boot down to see it), then unscrew the knob.
The ARC Ti shift knob appeals to me ARC Ti knob pic, but I'm not sure how much it is countersunk. See also Rick's accessories for some short-throw knobs.
Happy shopping!
Happy shopping!
I currently have the Team Voodoo Shift knob from Rick's. It is countersunk and lowers the shift radius by over 1". Installation is simple, as rehile indicated above. If you decide to go with a countersunk knob, you will also need to use some lock tight to hold the knob in place.
Here is a pic for your viewing pleasure.
Originally Posted by AaronS2000,Dec 27 2004, 11:47 AM
What is loctite exactly? An adhesive? Dont they recommend "blue"?
Originally Posted by AaronS2000,Dec 27 2004, 03:56 PM
so that nut u screw off, do u pull it off and then not put it back on before the voodoo knob? making it basically countersunk?
Originally Posted by AaronS2000,Dec 27 2004, 04:18 PM
thanks
and the adhesive is basically a glue that u put in the inside of the bottom of the knob or what?
