Royal Purple
i might have to try it out. ive just herd a bunch of mixed reveiws on RP motor oil with stock motors, but herd some good things on their tranny fluid
Originally Posted by lilsam012,Apr 9 2010, 10:21 AM
Ive done lots of Research on RP and im thinking about making the switch as well.
Mike any noticeable difference btwn mobil 1 and rp?
I use RP in the mill, but from technical data I have read: it's not as good as stock tranny oil. Ever try to use anything other than Honda genuine ATF-Z in one of their auto trannies? It works for a while...
Personally I will only use Honda MTF in the tranny. RP for the mill and Mobil1 in the rear. RP gear oil sucks in every test I have seen.
+1 for Honda MTF (& regular changes)
I think there might be a bit of confusion between motor, transmission, & diff oil going on - shouldn't be burning off transmission oil, should you ?!?
Pennzoil Platinum for the motor (& regular changes )
LE Duolec for the diff (& regular changes )
penzoil platinum!!! BOOO!!! thats a wax based oil...shittyyyy, Mobil 1 or valvoline..... and i dont burn any off, i just hit 25k miles and its never been done so i was planning on doing the diff and tranny
Originally Posted by InspiredAp2,Apr 14 2010, 10:15 AM
.... i just hit 25k miles and its never been done so i was planning on doing the diff and tranny
