CEL came on again
Filled up the tank yesterday and seated the gas cap by at least four clicks. This evening, the "check engine light" (CEL) came on
. Because this is not the first time this has happened, I immediatley pulled over and checked the gas cap. It was very loose
. Tightened the cap back up and was on my way. Now I'll have to wait several drive cycles to get the CEL to shut off (or pull a fuse).
This is the third time I was sure I properly closed the cap, to later see the CEL come on -- so I did a search and found the following useful links:
common problem - Xviper provides comments
how to live with the problem (see: ol' dood squeeze)
![frown.gif](https://www.s2ki.com/forums/images/smilies/frown.gif)
![mad.gif](https://www.s2ki.com/forums/images/smilies/mad.gif)
The CEL light is out now, after the third drive to-from work. Driving 50+ miles per day, I probably fill up more than most. Guess you can't always be in a hurry...
