Car audio Installation
Where did you guys and gals run your power wire thru the firewall at?
Did you use an existing hole and grommet or did you make your own?
Thanks
Thanks
Thanks
Just found a thread about it in the Electronics forum....
Silly me I should of checked there first!
But thanks jimmi.... we found it but where does it come in under the dash?
Do you remember?
Do you remember?
OK and Duane says get to work!!! (Or is that later tonite?)
Actually he said." What's he doing online? He's suppose to be working!"
Thanks again.... we're getting it done now!
Carefully cut the tape from the bundle behind the battery. Get about 3 foot of heavy wire. Bend one end of the wire so the is no sharp edge. Get the bend as small as possible. Tape your power wire to the other end of the wire. Now lube the bent end of the wire and the bundle and work the wire through the bundle. You may need to try several times before it goes through.
You'll know once your through. Move passenger seat all the way back and stick your head under the console. You should see the wire. One person continue feeding from the engine bay while the other keep pulling into the cabin
Notion
09-13-2002 05:23 PM
