VAFC II Tuner in Fl
VAFC II Tuner in Fl
Looking for a reliable tuning shop in Florida, preferably in SWFL/Tampa/Orlando/Miami Regions, to tune my VAFC II.
Thanks!
Thanks!
I'd highly recommend Real Street Performance (http://www.realstreetperformance.com...x.php?p=tuning) in Longwood (right outside of Orlando). The guys over there are great to deal with and really know their stuff.
If you research a bit, you can actually rent a dyno for an hour and tune it yourself. The VAFC is pretty easy to tune. I tuned my VAFC 1 after I had taken it to a tuner and he had messed it up a bit by not letting the car cool down after each pass. This made him lean out the settings and then for normal driving instances, it was running at 14-14.5 at WOT when it should be around 13.5. If you need some instructions on how to tune it, you can PM me and Ill send you all the basics.
the vafc is simple, change the vtec points and trim fuel, that's about it, once you start messing with it you'll get it down, i'd say it'd be better to spend the dyno dollars on putting in a wideband to your car and doing it yourself.
Why get tuned without a dyno? Seems unsafe to me, plus it's good actually knowing how much power youre putting down...every car's different, tuner even more so...just saying....pay the money get it done right, good luck-Justin
