check engine light
bung for the O2 sensor on the test pipe...you have to back the sensor away from the exhaust flow or its going to throw that code everytime... you can create your own out of two sparkplug anti-foulers but you have to drill one out to allow the sensor a place to screw into.
there should be a DIY thread about it in the under the hood section of this site:
https://www.s2ki.com/s2000/topic/229.../#entry4560256
there it is
some test pipes have this issue addressed with a bung that is already welded in...if yours has this,. and you are still getting codes, you need to pull the code and make sure it not something somewhere else in the system
there it is
joeyriveira
06-16-2003 07:14 AM
