2NR WERKS FTW!
2NR WERKS FTW!
Wassup everyone, took my car in for an alignment after installing KW Varient 3s over in tampa to 2NR Werks and man where they great! Ive read some posts on this site about them and I thought I'd give a shot with the alignment. While they were doing the alignment they noticed that the lower Bolt on the front drivers side had almost come completely loose!!!! (YIKES) So they fixed that and hen noticed that from my clutch install a couple of months back they noticed that the mechanic had not put in all the transmission bolts, he only put in enough bolts to hold the transmission to the motor in place! So they replaced all the missing bolts made sure everything was tight and they refused to take anything extra for about 2 hours of extra work. Who does hat these days? No one! So I just want to thank Todd and Bobby for a great experience, I'll see you for my next upgrade!
delliot, check your PM, I'd rather not post it here.
Xup, they do corner balancing I just opted not to get it done for now, maybe if I start autocrossing I'll get it done.
Originally Posted by xupthree60,Jan 31 2008, 05:30 PM
did they corner weight them as well?
If you did not do the weighted corner balance/alignment - then you need too! It is worth the money and I gaurantee you will not recognize the handling of your S!!!
J
