European S2000 Owners Covers: Austria, Belguim, Czech, France, Germany, Hungary, Italy, Luxembourg, Netherlands, Portugal, Poland, Slovakia, Spain, Switzerland.
Plus: Scandinavia and the Nordics. Covering: Sweden, Finland, Norway, Denmark, even Iceland, Greenland and the Faroe Islands!
4.44 Rear End Gear Swap
Old 04-09-2007 | 10:24 AM
Mr. S2k's Avatar
Post 4.44 Rear End Gear Swap
I bought me a set of these:
DISCLAIMER: The procedures, methods and products written up here was for my circumstances only. I make no assertions that your results will be the same nor do I claim that this is the best way to do it. USE AT YOUR OWN RISK!
Use HONDA SERVICE MANUAL along with this too. Especially when setting preloads.
Jack the car as high as possible. Remove rear wheels and put them under the car in front of a jack stand for safety.
I recommend you to put something under the front wheels.
1. Make a reference marks across the propeller shaft and rear differential then remove 6 prop shaft bolts with their spacers. Leave the shaft in the U shaped hanger that is already on the car.
2. Remove the cotter pin from the lover arm ball joint castle nut and remove the nut. To avoid damaging the ball joint, install a hex nut on to the thread of the ball joint. Be careful not to damage the ball joint rubber boot when installing remover.
It will make a real loud ˝POP˝ when the ball joint separates from lower arm.
I used Ball joint remover - Toll Nr.: 07MAC-SL00200
3. Remove ABS sensor harness from the upper suspension arm - 2 bolts on upper arm.
4. Make a reference marks across the inboard joint and the rear differential.
5. Remove 6 inboard joint mounting bolts and nuts, then remove the inboard joint from the rear diff.
6. Remove the rear suspension stiffener.
7. Remove the canister cover - thing that guards black plastic box.
8. Remove 4 diff mount bracket mounting nuts on the rear side of diff.
9. Remove 4 diff mount mounting bolts in the front side of a diff.
10. Take out rear differential.
My diff on the table with the output shafts popped out. I used rubber hammer to pop the shafts out.
Remove 10 mounting bolts in a crisscross pattern in several steps, then remove the diff case assembly. Whack the housing a few times with a plastic or rubber hammer till it comes loose. Separate the housing from the rest of the diff. Use a gasket scraper to get rid of all the old gasket material (it
Old 04-09-2007 | 12:35 PM
stocky's Avatar
Nice writeup!
But why this step: ?!
It will make a real ˝POP˝.
Old 04-09-2007 | 02:18 PM
Mr. S2k's Avatar
Originally Posted by stocky,Apr 9 2007, 12:35 PM
Nice writeup!
I meant that it makes really loud pop when the ball joint separates from lower arm.
I will edit that.
Old 04-10-2007 | 02:23 AM
Graphtuner's Avatar
nice writeup, very interesting stuff. Will study it later... thx anyway
Old 04-10-2007 | 05:11 AM
Tolgahan Ures's Avatar
Good write up
Old 04-10-2007 | 05:53 AM
Bombalahonda's Avatar
THANKS for sharing
how are the new gears?
are they wurth it
Old 04-10-2007 | 05:57 AM
Mr. S2k's Avatar
I am not using a full potential out of gears yet because I am still running them in. To tell you the truth, I am a little disappointed. I thought there will be bigger difference. But this not means that I don
Old 04-14-2007 | 09:24 PM
stocky's Avatar
I will edit that.
I understand but my question is, why are you taking ouit the ball joint!
You don't need to!
Old 04-15-2007 | 02:52 AM
Mr. S2k's Avatar
There is no way to disassemble half shafts from diff if you don
Old 04-15-2007 | 03:49 AM
stocky's Avatar
[QUOTE=Mr. S2k,Apr 15 2007, 10:52 AM] There is no way to disassemble half shafts from diff if you don
Quick Reply: 4.44 Rear End Gear Swap
