Suspension
Suspension
Ok guys, First time on the dragon with the S2000 the suspension was stock. Since then I have done alot of things to it. First off is how the car is going to react. I must stay in stock form the S did VERY well and felt very good. Going to the 245 rears helped alot. This time the car will be totally different. Full coilovers,Front and rear Bump steer from J's. ETB, STB, Alex sways. My alignment is the main question. I was to be able to keep the rear end planted as best I can. I like running the stock wheels so the tires I am running are going to play a major role. Im running S03 all the way around with a 215/245 combo, same as the first time. I need to replace the rear with something else but its hard to find a 245 for a 16" wheel. Any suggestions. Also suspension travel is going to play a big role as well. Curious to those running adjustable coilovers what kinda damping did you run in the front and rears. I know each setup is different but just trying to gather a little info before I go again. I have a extra day there to tune it in and get a good feeling. Any advice or discussion would be awsome, See ya guys there.
OVRSTR
03-16-2007 01:05 PM
