The Dragon modifications/maintenance thread
Old 02-14-2012 | 06:16 PM
frei's Avatar
Default The Dragon modifications/maintenance thread
What's up guy's/gals, just wondering what modifications/ maintenance items you have done to your "S" since the last time you been to the dragon. To the "first timers" you can post as well, this thread might help give you ideas to have your baby prepared for this event or future events to WTD/DBR. you can post pics if you like
I'll start...
new star spec front and rear tires on my ap2v1 rims 225/255
new oem brake pads
painted my calipers
engine/oil/dif fluid chance
a gopro 2 camera
4.77's & stage 1.5 rebuilt differential, built by puddydad (getting it installed this weekend)
and an alignment (after my new differential is put back on the car)
Old 02-14-2012 | 07:41 PM
s2kmiami69's Avatar
put new star specs on after i got back from dbr so those are good
rotors and pads were done all around just before dbr
diff/trans fluid was done just before dbr, just need to do the oil
gopro2 check
is it time to go yet?
Old 02-14-2012 | 08:29 PM
Bama Dave's Avatar
Since DBR here are my mods.
Eibach Pro Kit Springs on 2008 base model struts
1" drop and loving the handling with this setup
New Alignment
J's Racing 70rs single exhaust w/ Berks 70mm HFC (end of this month installed)
New Tires Bridgestone RE 760 Sports or Michelin Pilot Super Sports (Daily Driver)
Brakes are good
Diff, Tranny and Oil Changed
2-Hero2 Go Pros
Damn is it time to go yet!!!!!!
Old 02-15-2012 | 02:06 AM
FluKy15's Avatar
This year the differences from last year will be
starspecs, higher class of tire
endless race brake pads
will be installing brake ducting soon
test pipe
K&N FIPK
tune, 3900 vtec engagement now
Old 02-15-2012 | 04:29 AM
kgf3076's Avatar
Mods? Hmmmm...let's see...updated the iPod, chrome-plated floor mats, chopped and channeled door handles,changed the turn-signal fluid, reduced the GVW (went on a diet). I think that's all...
Old 02-15-2012 | 06:28 AM
werkinprogress's Avatar
Added 2 doors, half a liter of displacement, a turbo, AWD, a solid roof, lost a gear, and will have a stage 1 tune.
Same color though...
-Dan
Old 02-15-2012 | 07:02 AM
Bama Dave's Avatar
I need to know who changed the turn signal fluid and did it help with the handling of the car in tight turns on mountain roads. The GVW should really help if you ask me. That Canadian should have a hard time keeping up with you now. Installing the rumble seat next week for at least two more passengers can enjoy the open air experience too, you remember them Ken since you were born back in that era. I also added a two liter bottle of coke onto the engine so I want not have to downshift into second on the dragon like Brett. The car really likes the added power. See you guys later BD
Old 02-15-2012 | 09:17 AM
kgf3076's Avatar
I noticed that I now can hit VTEC at lower speeds in reverse with new turn-signal fluid. I was going to do the driveshafts with prop-wash, but I didn't have quite enough. I found another help was to change the cabin air. I used NC pine scented and now that dawg really hunts well (or in the vernacular...hunts gooder than most).
Old 02-15-2012 | 10:12 AM
Bama Dave's Avatar
Down here in Alabama we use the "Doe in Heat" scent in your cabin filters now that get some action with the male deer population down here. But you have to be sure to miss all the horny bucks trying to catch and hump the S when driving at night. Now that is a site to see.
Old 02-15-2012 | 10:30 AM
Looter's Avatar
Originally Posted by kgf3076' timestamp='1329329832' post='21417430
[quote name='Bama Dave' timestamp='1329321776' post='21416822']
[/quote]
Last year's Wake the Dragon, I had one of those so called "Bucks" do his best to jump into my "S" on the Dragon on the way to Fontana, coming from the Park Grill...on the way in...around 9:00PM...That was quite an awakening...Car wasn't hurt bad, knocked the driver's side mirror around, a couple of small dents ( dent doc fixed ) ....and lots of "slobber" inside the car....Scared the Hell outta me, though...
Quick Reply: The Dragon modifications/maintenance thread
