Brakes and Their Care and Feeding
#31
Originally Posted by Osky S2K,Feb 14 2006, 07:44 AM
Are the OEM pads adequate or is there a aftermarket pad you would recommend?
Also can you mix stock brake fluid with Motul brake fluid or should I just change entire system over.
Erich
Erich
For a one-time event like this, the OEM '04 pads will be great.
Don't mix fluids. Do a complete flush.
Basically, you open the bleeder furthest from the master cylindar (which would be the passenger side, rear.) And pump as much fluid out as possible WITHOUT letting air into the system. Fill the master with DOT4. Continue to pump fluid through until the fluid coming out of the bleeder is the DOT4 (if you use ATE Superblue, it is easy to tell, as the fluid is actually blue.) Continue to the LR, RF, LF in the same way.
#33
Originally Posted by ruexp67,Feb 14 2006, 07:36 AM
This is not exactly accurate.
Ofcourse it requires flush/bleed of brake system.
So hopefully that is clear.
#34
Originally Posted by 44Runner,Feb 13 2006, 03:07 PM
This kinda reminds me of another good safety point. Don't worry about what others are doing. If you can't keep up with the dude in front of you, don't sweat it. This isn't a race, it is an enjoyable weekend. And if someone comes up behind you don't sweat that either. Drive in your confort zone and pull off when there is a safe spot to do so...
Last year I had only had the car out for a month, and this was my first group drive. I refused to drive beyond my abilities, but I knew I would be holding people up. I never found out who it was behind me who was kind enough to repeatedly back off so he could get a better run at the upcoming corners.
#35
Lather, rinse, repeat.
#36
ruexp67,
Thanks for the advice!! I ordered stock 04 pads and ATE superblue today. I had the tire checked out and they said they have more than 1/2 tread left.
Is there any other things we should check other than fluids levels?
I am already to go to bad it is only February. I guess that gives me time to upgrade the stereo or maybe add a supercharger (LOL)
Erich
Erich
