let's talk rotors rotors rotors
honsport.com
Their site is down at the moment, but they've got blank Centric rotors for CHEAP. I mean freaking CHEAP. Ran a set of those on the track last year, they're good stuff.
If you really need the mad tyte horsepower of drilled/slotted rotors though, go for it. My friend had a set of those things on his car, and they were eating his old brake pads up. He got new pads, I told him to get rid of the rotors, he didn't, and they proceeded to chew up his new pads too.
I haven't replaced the brakes on my S2000 yet but I used Power Alloy Cryo-Treated Rotors on my BMWs for years. They last much longer than regular rotors and only cost a little more.
Here's a link: Cryo Rotors
honsport.com
TRUTH!! Thats what I used to replace mine. Got my old ones cut for cheap just for emergency stand-by units.
Originally Posted by HonCBRf2' timestamp='1301793712' post='20423838
yup, thats what I went with...slotted
Although drilled rotors have more surface area to dissipate heat, when considering the airflow patterns, the opportunity for air transfer for cooling would be minimal.
Originally Posted by GinoGT' timestamp='1301623639' post='20418054
honsport.com
Just got a quote from rotorpros.net for $200 ($240 for slotted/dimpled/drilled)for 4 rotors and pads. Seems like the rotors sold are centric standards, which I hear hold up fairly decently. Seems some guys on the EVO forums aren't happy with the centric standard rotors.
Standards. They hold up just fine on the S2000. Only difference between Premium and Standard Centrics are the black coating on the hat and outer edge of the rotor. I wound up cooking that finish off anyway during track use.
The whole surface area of drilled rotors is pretty much . The tiny gain in surface area does nothing compared to what you give up in mass (amount of heat they can hold), not to mention them being much more prone to cracking. If cooling is really needed, then you put together some brake ducts. Now this is not to say it's impossible to make durable, reliable cross-drilled rotors, you can. However, you're going to be spending a whole hell of a lot to do so for no real reason.
